99dyork
#1 Posted : Sunday, August 10, 2014 5:36:00 PM(UTC)
99dyork
the last few days, when I pressed the door open button, the door can't sprung open like it used to...
the door just opens slowly, or just ajar when pressed the door open button...
the door latch seems to work ok, and I saw the switch lever did came up when the door open button was pressed... but I only saw the bottom lever and did not see the top lever if there is one ....
today - the door will not open at all when the door button was pressed!!!
I downloaded the service manual but it had no instructions on how to open the door or its side to get access to the door assembly when the door is NOT open ...
any useful information to fix this would be greatly appreciated... PLEASE and THANKS ...
