AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
No power to flame sensor, gas valves, or ignitor
Great forum with lots of useful information.... Dryer info: Roper RGD4440VQ1 gas dryer Now my problem: Dryer wont heat up to dry clothes, the drum spins but no heat. The ignitor does not glow, no power to ignitor, coils or flame sensor... Things tried so far: 1- Checked the continuity of thermal fuse, cycling thermostat, thermal cutoff, and high limit thermostat at the back of the unit... 2- Checked the continuity of the timer, gas coils, ignitor, and flame sensor... 3- Checked voltage to the drive motor, gas coils, ignitor and flame sensor...(With and without the unit running in a timed high heat mode. 4- Checked voltage to door switch. Results of testing: 1- Thermal fuse was tripped (incomplete circuit). 2- All other components showed continuity. ( Ignitor read approx 119 ohlms (40 ohlms reference according to wiring diagram). 3- Drive motor voltage approx 120 vAC 4- gas coils, ignitor and flame sensor voltage = zero 5- Door switch voltage approx 120 vac Replaced: 1- Thermal fuse 2- cycling thermostat. Dont know what to try next. I think the problem might be in the timer since no power is getting to the gas coils, ignitor or flame sensor. Any help would be appreciated. Thanks in advance.
Groups: Expert
Dryer Repair
