Dryer initially ignites burner and warms up upon starting a new load. It runs approximately 5-7 minutes to warm and then burner goes out. A few minutes later, igniter goes through cycle but burner does not light. Igniter cycle continues every few minutes to try to light burner but fails. I have replaced Flame Sensor but repair did not fix nor change the problem. Gas Valve Solenoids??? Thanks!
