blankster
#1 Posted : Friday, August 8, 2014 6:25:19 AM(UTC)
blankster
On occasion I see icicles streaming from the ice bucket running down the side of the freezer. I replaced the ice dispenser door and solonoid since it seemed to stick open sometimes. That seemed to work for a month but this morning I see ice and water dripping from the ice bucket again. Also an item on the top shelf seems to have softened a bit (due to the water dripping on it?). Is my ice despenser bad? The temperature readout on the LCD display always shows zero +- 2 degrees. Does the tension on the dispenser door spring need to be wound one turn to increase the tension? Is my ice dispenser bad?
