suvigb
#1 Posted : Wednesday, August 6, 2014 3:24:36 PM(UTC)
suvigb
My Whirlpool GU3200XTSS1 dishwasher is leaking from the front. The leak does NOT seem to be from the water intake. It looks like I have a small waterfall from the from chasis which is all 1 pc.
Can see to figure out what is causing the leak.
thx
Suvig
#2 Posted : Thursday, August 7, 2014 12:33:31 AM(UTC)
A flashlight and a small mirror may help you track down the cause of the leak.
A mechanics mirror is ideal this is like a dentists mirror except larger.
You could attach (tape) a small mirror at an angle to a dowel so you can see up into the unit.
Often where it drips is not where the leak is as the water is running down the unit's walls etc. till it reaches a low point.
