micropterusal
#1 Posted : 11 years ago
micropterusal
I recently replaced the transmission/brake assembly on my washer and also replaced the tub washer, tub bearing, split ring and washer. After reassembly I found that I had three (3) screws left over. (see attached photo). I think they came out of the outer tub assembly somewhere as they were grimey like the rest of the tub parts due to tub seal being worn out. Screws are brass, 3/4 inch long and a size 15 Torqx bit is required. I looked many times at the assembly and cannot locate the screw holes.
Any help appreciated.
micropterusal attached the following image(s):
fairbank56
#2 Posted : 11 years ago
fairbank56
Groups: Expert
Looks like the screws that attach the tub balance ring to the top of the inner tub.
Eric
