agrodon1
#1 Posted : Thursday, July 31, 2014 11:01:50 AM(UTC)
agrodon1
Can anybody tell what error code F2 mean? It appears on the control panel for the whirlpool GBD277PDB5 double wall oven when I try to start the oven
#2 Posted : Friday, August 1, 2014 12:12:15 AM(UTC)
Parts for Whirlpool GBD277PDB5 Wall Oven - AppliancePartsPros.com
The tech sheet gives the error codes.
Try unplugging the unit for a few minutes to see if the error will reset/clear.
If not then perhaps try the following especially if it also gives a E1, E5 or E6.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
If the above does nothing then I would replace the keypad first.
Note: There is not a good way to check it as they do not publish the keypad outputs.
File Attachment(s):
GBD277.pdf (302kb) downloaded 6 time(s).
Whirlpool Duet Dryer Error Code f25 (Dryer Repair)
by wwwhitley 10/30/2015 12:09:40 PM(UTC)
whirlpool duet sport dryer Error code F29 reappears (Dryer Repair)
by Herennow 4/14/2015 3:36:40 PM(UTC)
Whirlpool error code f27 (Washer Repair)
by CRita 7/24/2013 5:37:50 PM(UTC)
GE oven error code F2 (Oven Repair (including Ranges and Cooktops))
by Tinadwalker 6/8/2013 4:26:29 PM(UTC)
Error Code F24 (Oven Repair (including Ranges and Cooktops))
by stampede 3/17/2013 2:57:15 PM(UTC)
KitchenAid Error code F2E1 (Oven Repair (including Ranges and Cooktops))
by meter12 2/2/2013 9:26:43 AM(UTC)
kenmore he3t, error code f28 (Washer Repair)
by bleonard 11/19/2012 11:15:17 AM(UTC)
error code F2:E3 (Oven Repair (including Ranges and Cooktops))
by brylev 6/19/2012 8:45:57 AM(UTC)
GE Error Code F2 (Oven Repair (including Ranges and Cooktops))
by jasonroach 5/20/2012 3:53:45 PM(UTC)
by wlemacks 10/7/2011 9:08:21 AM(UTC)
by wlemacks 10/7/2011 8:52:57 AM(UTC)
Error code f21 (Washer Repair)
by Waldo.S 9/15/2011 9:54:43 AM(UTC)
Error Code F21 Washer not draining (Washer Repair)
by Mr Bubba 9/6/2011 5:25:49 PM(UTC)
error code F22 (Washer Repair)
by sparks87144 8/20/2011 7:48:59 AM(UTC)
by sparks87144 8/20/2011 7:44:42 AM(UTC)
