DCANDY
#1 Posted : Thursday, July 24, 2014 7:49:12 PM(UTC)
DCANDY
No Pressure At Sprayarms, It Squirts Out In A Solid Stream About 2 Inches, But Not Enough To Move The Sprayarm. --- I Removed Impellers, Both Wash And Drain, They Appear Ok, ---- Replaced Both Upper And Lower Bushings On The Sprayarm, Still No Pressure --- Lots Of Water Movement Around The Filter, I'm Losing Pressure Someplace, Maybe A Gasket/seal.... When I Reassembled The Unit I Did Not Replace The Gaskets/seals, But The Problem Begin Before I Disassembled It --- Did It Blow A Gasket/seal Someplace ??
DCANDY
#2 Posted : Wednesday, July 30, 2014 6:27:37 PM(UTC)
DCANDY
TRIED ADDING MORE WATER -- DID NOT WORK, HELP !!
