Freezer and frig not cold enough. Inside light only works for about 5 mins after plugging frig in. LED temp setting lights continue to work. Cooling fan comes on immediately upon plugging in. Compressor sounds like it comes on after about a minute. I read somewhere that a faulty door switch could cause temperature setting issues. Any thoughts? Is the light not working after 5 mins each time I plug it in an indicator? Thanks for your time and suggestions.
gee ... over 80 views and not a single comment ... thanks for the help :( ... smh
I am not surprised that you did not get a reply. Your unit is actually a LG. I have been doing this for a number of years and have never found a cross reference for Kenmore/Sears units to the actual manufacturer so finding tech info is difficult. Also Sears does not give out tech data, they send out repair people. I can give you a link to a site with some LG manuals perhaps you can find one that is close or with luck a match to your unit. You will have to join the site and be logged in to be able to download them is the Manuals section. http://appliancejunk.com/forums/Also below is a site with basic fridge repair info perhaps that will help you http://www.applianceaid.com/refrigerator-help-section.phpYou have strange symptoms so I doubt anyone has actually seen what you describe. |
THIS FORUM IS DEAD!!!!!!! |
