georgejacob
#1 Posted : Wednesday, July 23, 2014 5:19:58 AM(UTC)
georgejacob
The freezer is cooling and but not the fridge main compartment. A repair person checked and replaced the mother board ($300) and the fridge worked for just over a week.
I am able to warm up the fridge till the freeze around the back of the freezer is thawed and fridge works fine for a week more or so.
Browsing through the web looks like I need to change the temperature sensor, but I am not sure how to get to the evaporator assembly. ANy help is appreciated
PFS22SBSSS is a Canadian MODEL Number, US model closest is PFS22SBSASS.
George
#2 Posted : Thursday, July 24, 2014 1:49:54 AM(UTC)
Most probable problem is the defrost heater. Remove the freezer back panel, defrost the coils and check the heater, if black inside with a gap, it's blown.
georgejacob
#3 Posted : Friday, July 25, 2014 6:54:48 AM(UTC)
georgejacob
Thanks will check this week end
