marcel-d1
#1 Posted : Sunday, July 20, 2014 12:30:42 PM(UTC)
marcel-d1
** My Bosch dishwasher continuously drains and will not advance to the next cycles. However, I was able to locate the red stick in the bottom left corner behind the kick panel. This red stick is connected to the float and activates the float switch. When I hold the stick down by using a long flat head screwdriver the dishwasher advances to the wash cycle and fills and the spray arms start working. As soon as I let the stick up the cyle stops and the dishwasher drains.
Does anyone know what I need to fix?
The other problem I have with this machine is the rinse agent dispenser continuously releases rinse agent and the dishwasher foams up.
