djbindust
#1 Posted : Wednesday, July 16, 2014 3:53:44 AM(UTC)
djbindust
I have a GE Profile Washer PFWS4605L0MG that will no longer turn on. It started intermittently acting up after it was moved to a new location. Then finally just died. Outlet verified to have power so from what I have seen on blogs it points to the control board WH12X10469.
Before I spend $300+ on the control board are there any tests that can be done at the control board connector to verify that it is getting power?
I have tried searching for a wiring diagram and a Technical Service Guide for the washer but have not been able to find either. Any help appreciated.
