AppliancePartsPros.com
Appliance Repair Help
Washer Repair
washer will not turn when filling then flashes f51
My whirlpool washer starts fine but when it comes to the part in the cyclewhen The tub should start turning while the water goes in to get the Tub to get the clothes wet it just sort of pulses while the water goes in To the tub, then a f51 comes up. :eek:
Check under the top or inside the lower service panel for tech notes. They will tell you how to interpret the error code and how to test some components.
If you still need help please post a model number so we can see which machine you have.
Good luck.
Washer Repair
