The dreaded goes to clean light syndrome. Does anyone have a service guide so I can run diagnostics on interpret the codes for this thing. I have cleaned and checked the water valve, cleaned the pump inlets, pulled the pumps and inspected and found no debris. The drain pump will come on for about five seconds, then the circulation pump, then the drain pump again and then it goes straight to clean. I held the delay and > while pressing the power button and the active and clean light came on. I then pressed the < and it went into a cycle. I don't know if it was a normal or diagnostic cycle. Any suggestions?
