I installed new ERC #316560156 and still same problem.No convection broil. I looked at tech manual and found no help. Is there a service bulletin or special programing for this option? Oven is supposed to have this feature.Convection bake and roast work. Seems like control doesn,t have correct program installed in it.
I cannot give you a definitive answer to this. I did go to their service website but nothing came up about this.
I can tell you that I am doubtful this involves having to do some programming to activate this one feature at least I have never seen a unit that needs special install procedures just to activate one feature.
Your best bet is to contact Frigidaire.
Convection bake and convection roast is fairly common on many Frigidaires. Convection broil is not, it may depend on the revision or there may be a different part number for the control board. |
THIS FORUM IS DEAD!!!!!!! |
