So my Monogram fridge stopped working. Called fridge guy who came out and charged with R-134a. 30 days later it no longer chills. I put some R134 with UV dye in it, and I don't seem to be able to see a leak. That's bad because it means it's probably in the evaporator coils, which are difficult (impossible?) to get to. So, first question. Here's the coolant diagram that came with the unit:  How the heck does that work? There's only a single line that goes to the evaporator. Huh? That means there's no cycle through the evaporator. Could someone please clue me in on how this functions? So, what are my options here? How hard is it to tear into the case to get at the evaporator? Can I just hang a different refrigerator's evaporator in the back of the unit and just solder it it (i.e. completely bypass the failing evap). If so, how would I find an evaporator that would work right? In general, I'd simply say this is too much of a repair, and just buy a new unit, but the damn thing cost nearly $2000 and it's only 5 years old. Save the small refrigerant leak it's mint. I'd hate to scrap something like this over such a small problem!
Look up the purchase date. I looked at the owners manual and it says the sealed system has a 5 year warranty.
It think that you only have one line going to the evaporator because it is a simplified drawing.
Putting in another evaporator is not feasible as there will not be room for one.
You cannot find the leak. It may even be in the compressor so until you find it what will be required to fix the unit is unknown.
Sorry I do not know how to take this unit apart. With luck someone else will jump in who has worked on one. |
THIS FORUM IS DEAD!!!!!!! |
