Ordered Part# 8203536 which is verified replacement 1000/2400 watt infinite switch for LF burner.
Problem is wiring codes & terminal #s don't match. ie:
Original switch: Terminal # 1 Dk Red location on old switch Left side middle 2 Black Left bottom 3 Dk Red Rt bottom 4 Brown Rt Top 5 Red Left Top 6 Orange Rt side middle
Replacement 8203536 instructions read: Old Switch connect to New switch Terminal # Terminal # 2 P1 3 4 4 4a 5 S2 N or Brown wire 2 N or Red wire P2
Both N's don't conform. There is 1 Brown & 1 Red. They are sent to 4a & S2, per the instructions. This leaves 1 Dk Red (#1 term) & 1 orange (#6 term) with no place to go.
What is correct terminal & color code for new switch?
Hi i replaced that same burner control (LF kitchenaid ceramic top)and the burner works, but the 'pilot lamp' for the LR burner comes on and stays on... i went to investigate and started looking at those pin labels and , ya, something seems a bit weird. i took before and after pics which perhaps would help. hmm.
-back in a bit.
