My kenmore washer leaks water (don't know where) water all over floor
The usual suspect here is the drain hose leading from the tub to the pump and then on out. Check it first.
Thanks for your input. Hopefully I can have my son-in-law look at the washer. My husband can not due to brain cancer. Judy
We are so sorry about your husband. Good luck with your machine, hope it is an easy fix.
