I have a GE GTDP200GM0WW Electric Dryer, I need to replace the backsplash/control panel. Does anyone know if I can use the backsplash panel from a GE DBXR463ED2WW? The panels look so similar & I can get one for cheap I'm just no sure if it's compatible. Any help would be greatly appreciated, thanks so much.
Was thanked: 10 time(s) in 10 post(s)
I do not think it will work. The units use different timers/knobs. Also DBXR463ED2WW uses a timer support plate behind the control panel and your unit does not. On top of that they use different end plates. |
THIS FORUM IS DEAD!!!!!!! |
