Groups ready for retrieval: Registered
For the past few months the dryer has not shutting off occasionally. Like the timer just freezes part way thru cycle. But not everytime. The other day i was drying a blanket and I went to check if it was done. It wasn't running but the timer was half thru cycle. The blanket had split open and all the stuffing completely filled the lent tray to bursting.
Now it will not start at all. I select cycle and push the start button and nothing happens. Please help.
I cannot find any info on the given model number. Please check it. Find your model number - AppliancePartsPros.comThe thermal fuse has probably blown. On most units this is mounted on the blower assembly. It would be a good idea to check/clean the air flow path in the unit. Also I would check/clean the vent system. |
THIS FORUM IS DEAD!!!!!!! |
