Hi, I have an almost 2 year old GE top load washer (model GHWN5250D0WS). I ran a load of whites Sunday evening and the washer worked fine. Last night I tried to run a load of colors. When I started the cycle it seemed like it was filling much slower than normal. A little while later it was filled and agitating. Later I noticed it was stopped. I assumed it was done but when I lifted the lid the fabric softener was still in its dispenser. I turned the machine off and back on and started the cycle over. I again notice it was filling very slowly. If I changed the cycle to whites the water filled normally. Set it back to colors and let it run. Later when it was done I opened the lid and the clothes were very wet like they didn't spin. Ran a spin/drain cycle so the clothes could go in the dryer. So it seems like the slow fill is throwing the whole cycle timing off. What would cause this? thanks, Gary
Problem resolved: clogged cold water inlet screen.
