Nhebayer
#1 Posted : Tuesday, July 1, 2014 3:39:36 AM(UTC)
Nhebayer
Im considering buying a Stackable Frigidaire set... Front Load Washer works fine.
Seller says the dryer will spin as soon as the door is closed... but the heat dont turn on until the button is pushed.
Easy fix or not? Is this a timer or control board or something else?
Thank you for the help
Reaney in NH
fairbank56
#2 Posted : Tuesday, July 1, 2014 5:18:52 AM(UTC)
fairbank56
Groups: Expert
Sounds like the motor relay on the control board is stuck closed. New control board runs $183.
Eric
