The vents between the fridge and freezer are icing over. When this occurs the freezer temp is good however the fridge gets warm. The seal around the door appears to be intact and I cleaned it. It appears the next step is to remove the back panel in the freezer and check out the coils. Just do not understand why it is the vents icing over. aeb
