I have a side by side Frigidaire. It stopped cooling properly. I cleaned condenser coils. Freezer at 30 degrees, Fridge at 40 degrees, defrost cycling regularly. I replaced control board. Freezer at 40 degrees, Fridge at 50 degrees, defrost is cycling regularly. Compressor, Evap Fan running. Compressor is a little warmer than room temp. No leaks at door gaskets. I have turned thermostats off for a few minutes and restarted. Air seemed colder just after restart but didn't continue getting colder. What's next? Cold controls?
Remove freezer back panel and describe frost pattern, total heavy frost, or partial.
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Originally Posted by: richappy Remove freezer back panel and describe frost pattern, total heavy frost, or partial. Partial frost at top of evaporator.
You have sealed system problems assuming the condenser fan is ok.
Originally Posted by: richappy You have sealed system problems assuming the condenser fan is ok. Condenser fan is running. So you think it's a refrigerant leak or compressor issues. My condenser coils were covered pretty good before I cleaned them.
Your compressor may be leaking internally due to thermal stress.
Originally Posted by: richappy Your compressor may be leaking internally due to thermal stress. I was HVAC certified in 2007, I never truly pursued it outside of helping family, due to getting a better position at my job. Do you think it's worth having the compressor replaced? I do recall from school that once you open a sealed appliance system you could have some bad results.
A big no there, not worth it.
Originally Posted by: richappy A big no there, not worth it. Thanks for all your help ric.
