hh351
#1 Posted : Saturday, June 28, 2014 3:53:12 PM(UTC)
hh351
My refridgerator stopped cooling and was making clicking noises so after pulling the starter relay near the condenser, I saw that it was burned, cinged at the base near the wire. I ordered the correct part Electrolux 5303007171 which is a replacement part since the original part G182225-11 was discontinued. The problem is the replacement part is larger than the original part which makes it impossible to reinstall the box cover
#2 Posted : Sunday, June 29, 2014 5:16:28 AM(UTC)
You are missing the spring wire that holds the start device in place. For normal operation, you can run it without the wire.
