The temperature display is erratic. Suddenly ir says 59 and 23 (fridge Nd freezer), but the actual temperature does not appear to change. I have a digital thermometer on a shelf. I unplugged it and after a litlle while ( maybe one hour) it comes back to normal. Di i have to change the board ?
Post the freezer temperature, if not below 20 degrees, check the evaporator coils for total, heavy frost.
