briann1970
#1 Posted: : Tuesday, June 24, 2014 7:45:08 AM(UTC)
briann1970
when I start the washer it fill not fill with water, hot or cold
fairbank56
#2 Posted : Tuesday, June 24, 2014 10:47:53 AM(UTC)
fairbank56
Groups: Expert
Check to make sure you have power at the receptacle.
Set timer to spin and try it. If no spin, no timer advancement, no noise at all from washer, the most likely problem is a bad lid switch. Lid switch on these load sensing models kills power to everything.
Whirlpool 8318084 Lid Switch - AppliancePartsPros.com
Eric
