Forum Rank:: Member
I have a 3yr old kenmore dishwasher that makes a clicking sound and leaks. When i first start the cycle there is no noise and no leaks, then about 15-20 mins into cycle it makes a clicking noise and leaks from the drive motor ( attached pic). everything ive read about leaks from these dishwashers none of them say anything about leaking through the drive motor, so my question is where else would make it leak through motor and what parts should i change. and would the clicking noise be coming from the motor. while it made the noise i kicked dishwasher and it stopped briefly. any help would be appreciated thanks nystateofmind attached the following image(s):
Forum Rank:: Member
Hey anybody, please need some help. thanks
