frustrated when I first got my fridge I just held lock and water like it says on the panel and light would reset this no longer works I got it to rest once but cant remember how I did it hitting light switch 5 times doesn't work lock andlight doesn't work any ideas thank you
A model number may help others help you.
You could try unplugging the unit for a couple minutes to see if it will reset. |
THIS FORUM IS DEAD!!!!!!! |
