coasterfamily
#1 Posted : Wednesday, June 18, 2014 2:32:26 PM(UTC)
coasterfamily
I have to keep on moving the shelves so one side doesn't fall
#2 Posted : Friday, June 20, 2014 3:46:02 AM(UTC)
I am assuming these are fixed shelves that are not pulled in and out.
Also that they do hold correctly as long as they do not move to one side.
Also that they fit into slots of the sidewalls.
I would get some tape what type should not really matter.
Then build up a number of layers on each side of the track in the side walls where the shelves ride.
Would be nice if you could find a tape that is the correct width to fit in the track.
Put an even number of layers on each side till the shelf is snug not tight.
Now it should not be able to drop out.
coasterfamily
#3 Posted : Friday, June 20, 2014 3:55:48 AM(UTC)
coasterfamily
Simple and great idea
