My “LDF7932ST” started making a strange noise a few days ago. The sound waslike a propeller that was broken (sorry not being so clear). I found that theunit wasn’t draining. Then an error alarm and code of “LE” started. I took thesump assembly apart to inspect the impeller and only found some stringing materialaround the motor shaft. I then cleaned and put it all back together with no change.Still get the “LE” code. Any ideas on what my next step should be? :confused:
Hello, thank you for asking your question here. The "LE" error code stands for locked motor/rotor. Take the sump apart and make sure chopper and motor shaft spins freely. If they both spin freely, the motor assembly needs to be replaced because it's shorted. Appliance Repair Portland
