So having read some forums on this model and brand I NEVER use the self cleaning function. But today, the oven will not turn on despite it not having been used for a week. I know it is getting power as evidenced by the oven light still working on the control panel and the "beeps" whenever buttons are pushed. So I figure it's the control panel or possibly the thermal fuseā¦ the former is $165 the latter $17. I am a consumer not a repairman but I was able to remove the control panel but how do I know if the thermal fuse is blown? I also tried resetting the breaker several times. No luck.
Any advice and part numbers help would be greatly appreciated!
Hello, thanks for asking your question here. If the control panel beeps, then the fuse is good and the board is bad. The control panel would not beep if the fuse was bad. If you wanted to test the fuse, you would need a volt/ohm meter. The fuse should have continuity. Unfortunately, the control board on this model is no longer available. There is a company that rebuilds them though. You have to remove the part and mail it in. Normal turn around is about a week. The name of the company is core centric. Refrigerator Repair Portland
I searched and several places yesterday that listed they have the control panel in white… Now i cannot seem to locate them in my history. Are you sure they are no longer available? What does this cost?
Everywhere I'm looking shows the part No Longer Available. If you go to core centric it will have a price for rebuild and turn around time. Refrigerator Repair Portland
