chehs01
#1 Posted : Monday, June 16, 2014 9:41:40 AM(UTC)
chehs01
Hi all,
My Whirlpool ED25PEXHW01 side by side refrigerator stops working. I tried to unplug and plug the power, but nothing runs except the light. No fan running.
I tried replacing the defrost timer as the video Whirlpool 482493 Refrigerator Defrost Timer Kit - AppliancePartsPros.com
I set the configuration to version 2 like the video suggested. But the refrigerator still doesn't come up. But I hear clicking sound when I adjusted the refrigerator temperature on/off. Any suggestion what may be the problem with the fridge? Thank you very much.
John
#2 Posted : Monday, June 16, 2014 4:26:44 PM(UTC)
Check the compressor in the back, it should be vibrating. Also, check the condensing fan motor.
chehs01
#3 Posted : Monday, June 16, 2014 5:47:06 PM(UTC)
chehs01
Nothing from the compressor and fan at the back
#4 Posted : Tuesday, June 17, 2014 1:34:51 AM(UTC)
You wired something wrong at the timer.
#5 Posted : Tuesday, June 17, 2014 1:35:03 AM(UTC)
chehs01
#6 Posted : Tuesday, June 17, 2014 3:08:32 AM(UTC)
chehs01
Thank you richappy. I wired to Version 2 (pin 1) like the defrost timer video because the refrigerator in the video looks just like mine. What was I supposed to wire the defrost timer to for my fridge model ED25PEXHW01 side by side refrigerator? I don't understand the schematics... Thanks,
#7 Posted : Tuesday, June 17, 2014 7:08:04 AM(UTC)
Could be a connector came loose behind the control panel.
