I have a French Door Ref that is not getting cold at all, the freezer and the refrigerator. I’ve tested the compressor and getting same 7.6 ohms reading on all. Is it because this is a 3 phase compressor and not a single phase? Or the problem is not the compressor at all? I would really appreciate any thought and input I can get to fix and pinpoint the problem.
Most probably a bad inverter, compressor may be ok.
