AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
drum sounds like it is rubbing (loud) as it runs
We bought this from a neighbor who was moving but they said it worked fine. When we turn on the dryer there is a loud rubbing sound as the drum spins.
Originally Posted by: rickimb67 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) We bought this from a neighbor who was moving but they said it worked fine. When we turn on the dryer there is a loud rubbing sound as the drum spins. there is a loud rubbing sound when the drum is turning
Here are your parts Parts for Maytag SDE515DAYW Dryer - AppliancePartsPros.comRun your fingers along the inside of the drum seal at the front and back of the drum, to see if anything is between the drum and the frame. Bra wires are famous for this. Be careful just in case the object is sharp. If the above is OK then it could be a lot of things. At the top of the list would be worn front drum support glides. |
THIS FORUM IS DEAD!!!!!!! |
Dryer Repair
