AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
LG DRYER not rotating and cooling light is always on
I have an LG TROMM DLE 2515S that was working fine other than the "cooling" light always being on. Now it has decided not to rotate at all. I have power to the main board, meaning everything lights up and works as normal, but it will not rotate. I have replaced the moisture sensor bars and the door button (center front of dryer behind the door). I am thinking it is either the motor or the thermal fuse or maybe both and would like to get some advice before I invest in more parts (I've already replaced the drum and rollers). The parts I have found are 4681EL1008A for the motor and 6931EL3003D for the thermal fuse....any advice on troubleshooting further would be immensely appreciated!
Thanks, Jody
Dryer Repair
