postonglover
#1 Posted : Saturday, June 7, 2014 7:35:28 AM(UTC)
postonglover
A power failure occurred while we were on vacation. The panel works, but oven will not heat at all. I have checked the Sabbath Mode, Timed Cooking, and Control Lock, but resetting these has not changed anything! Help!:eek:
#2 Posted : Tuesday, June 10, 2014 1:04:02 AM(UTC)
First you have to check the power.
The elements require the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug.
Your unit may be hard wired so extra care must be used when checking for 2450 volts.
L1 to L2 should be 240 volts
If OK
If OK
KitchenAid Electric Oven Won't Heat (Oven Repair (including Ranges and Cooktops))
by frosini 10/1/2018 7:23:00 AM(UTC)
