Scott Eddy
#1 Posted : 11 years ago
Scott Eddy
Agitates while it's filling with water,what could be the problem and how do I fix it?
sidfink43
#2 Posted : 11 years ago
sidfink43
I would start by changing out the timer. If you get the part from this site and that is not the problem you can return it. But before doing that check out the water level switch by blowing into from the tube that connects it to the tub and see if it is engaging or stuck.
