j409
#1 Posted : Monday, June 2, 2014 7:44:19 AM(UTC)
j409
The washer will not spin anytime. Whether in spin or wash. It will drain, I'm trying to get some help with what could possibly be wrong or needed fixed. Thanks
sidfink43
#2 Posted : Tuesday, June 3, 2014 4:51:45 PM(UTC)
sidfink43
There is a error code generator on the inverter which is on the motor. It should have a flashing green light. You can access it by removing the front panel which comes off if you insert a thin flat blade screw driver in the gap between the front and top about 3 inches in from each side.
Here is a link to a site that will tell you how to interpret the code. Try resetting the machine first, sometimes that is all that is needed.
HydroWave GE Washer Repair Guide
