I have couple of the smooth top burners getting red hot when control temp set to 4. Or sometimes it is just half red. Was front burner than less than a month the back burner on opposite side has did it also. Don't know what is wrong with it
Most likely it is a bad infinite switch that controls the element. |
THIS FORUM IS DEAD!!!!!!! |
