Ben Anson
#1 Posted : Friday, August 10, 2007 11:04:48 AM(UTC)
Ben Anson
I need help. My washing machine is not spinning. I checked the power coming in to the machine it is ok. I tested the silinoid on the part called the "Wig Wag" The problem is that the silinoid is not getting power from the timer switch. I checked everything else including jumping the main power to the wires going down to the silinoid. When i do that the silinoid engages and the washer spins. I even replaced the washer timer Part # AP3099617. When i replaced the timer the washer did spin for 5 seconds and then stoped.
Do You Have Any Other Ideas.
jdman
#2 Posted : Friday, August 10, 2007 3:49:52 PM(UTC)
jdman
Check the lid switch. You can do this by jumpering around it as well
