The range light and fan on this microwave went out after a power surge. Everything else on microwave works well. There's a small switch that I need to replace to correct it, but I cannot remember the name of it. I know the purpose of the switch is to turn off the light and fan when the power surges, but don't remember what it's called.
Any and all help will be greatly appreciated!
Quote:...the purpose of the switch is to turn off the light and fan when the power surges... There is no such switches in the microwave. The surface lights and the fan motor operated by the control board and, most likely, this control board got damaged. - The control board Part number: AP2026021
