knowles779
#1 Posted : Thursday, May 22, 2014 6:37:32 AM(UTC)
knowles779
Won't spin fast enough to extract water from clothes. Drains fine. Have replaced belt, and pulley/brg on bottom of transmission. What next?
sidfink43
#2 Posted : Saturday, May 24, 2014 5:02:52 AM(UTC)
sidfink43
I cannot tell from your post if you replaced the entire thrust bearing assembly, if not you should do so as that is the usual problem here.
If you have, make sure you have adjusted it properly with the right amount of washers. Then check to make sure nothing is hanging up between the tub and basket.
Good luck, hope this helps.
Guest (4)
