xxmanutdxx
#1 Posted : Tuesday, May 20, 2014 8:50:49 AM(UTC)
xxmanutdxx
Recently when I shut my microwave door there are times the light inside the microwave stays on and the turn table spins slowly. The microwave is not heating anything. If I open up the door then the turn table stops spinning, but once I close it again, the light still stays on and the turn table spins once again.
There are instances if I shut the microwave door hard enough, then the light will go off and the turn table does not spin.
Any idea what is wrong?
Thanks in advance.
