smieri6
#1 Posted : Saturday, May 17, 2014 4:51:20 PM(UTC)
smieri6
My front load washer won't stop filling up with water. It does everything else right but it fills with too much water.
sidfink43
#2 Posted : Sunday, May 18, 2014 5:58:09 PM(UTC)
sidfink43
I don't get your model number to come up, but normally when this happens the tube going to the pressure switch is blocked, or the pressure switch itself if malfunctioning.
smieri6
#3 Posted : Sunday, May 18, 2014 6:10:30 PM(UTC)
smieri6
What's the pressure switch and where is it located?
sidfink43
#4 Posted : Sunday, May 18, 2014 6:32:06 PM(UTC)
sidfink43
Take off the top and see if there is a plastic tube leading to a part. I cannot tell you any more because your model number is either incorrect or this is a non Us machine, either way I cannot get an exploded diagram of your model.
smieri6
#5 Posted : Sunday, May 18, 2014 7:41:17 PM(UTC)
smieri6
I'll recheck the model# on tomorrow and get it back to you. Thank you very much.
smieri6
#6 Posted : Sunday, May 25, 2014 9:55:03 AM(UTC)
smieri6
This is the model #W10284544 A
