yzhong
#1 Posted : Wednesday, October 21, 2009 1:44:50 PM(UTC)
yzhong
GE refrigerator Model Number TFX24FHB
Problem: The right side fresh food door can be closed only after it is pushed firmly. Otherwise, it will always leave a small open. I tried to adjust the two slot positions for the two screws on the door outside top, but it did not help. I found the gasket had one broken area. How to fix the problem? Please advise me. Thank you very much. Adam
#2 Posted : Wednesday, October 21, 2009 2:58:28 PM(UTC)
Replacement parts for GE TFX24FHB | AppliancePartsPros.com
Check the cam risers on the bottom of the door, perhaps one of them is busted. See Item 451 in the "Fresh food section"
Click on the picture and you will get a better view.
Sometimes the gasket on the hinge side rubs/grabs when closing put a light coating on white lithium grease on the frame or the gasket. You do noy need much.
