srtlt
#1 Posted : Wednesday, October 21, 2009 1:33:33 PM(UTC)
srtlt
My front load Frigidaire washer will not complete a wash goes through until final spin then gives error code E20. I cleaned the drain hoses thinking maybe it wouldn't drain so it wouldn't spin but that has not worked.
sidfink43
#2 Posted : Friday, October 23, 2009 8:54:06 AM(UTC)
sidfink43
The speed or motor control board frequently fails on these models.
See if you can locate a tech sheet inside the machine after you take off the lower access panel. Then clean out the pump area and try to go through the diagnostics in the sheet.
