paul999
#1 Posted : Sunday, May 11, 2014 1:57:14 PM(UTC)
paul999
Low water pressure at the water dispenser. Replacing the filter did not help.
When I remove the filter and put the plug in its place the pressure is fine.
I then put the filter back, and it works fine for about a day. The pressure is at a trickle.
paul999
#2 Posted : Sunday, May 11, 2014 5:34:54 PM(UTC)
paul999
There is no problem with the ice maker. The cubes are full size and solid.
