clothes are too wet after spin cycle-have replaced belt and tensioner spring and cleaned pulleys-pump turns freely by hand but can hear bearing noise when pump is turning and I listen to it with a mechanics stethoscope-drum appears to spin fast enough but hard to tell-I think there is a slight growl or hum in spin cycle I dont recall it having before this problem-your advice?
Take it apart and check for any obstruction in the hoses leading from the tub out to the pump and beyond the pump. If they are clear try replacing the pump.
If the machine is spinning fast enough and the pump is working and there are not obstructions in the hose the clothes must spin to a damp dryness.
