Bill Henry
#1 Posted : Saturday, May 3, 2014 6:45:04 PM(UTC)
Bill Henry
The dryer will not work. The pause/cancel light is on all the time. If I press any of the control switches the light will blinka few seconds and then return to steady light. I thought the power supply board may be the fault but do not know how to get to it. The 220 volt is okay. The door switch is okay. I have checked other things all okay. Is the pause/cancel led indicating the problem?
How do I get to the power supply? Your help is needed and I thank you if you can help.
